[2] also watch out for cracks in s/d in wet side mine cracked when i charged with co2 the rapid temp change caused the cracks i took a very small drill bit and drilled the end of crack to leep it from growing over dry side bulkhead then coverd up alum tape. caswell said that if it moved over to dry side they would make it wright
