More Production Photos from The Cave
ID:	100029Click image for larger version
ID:	100030Click image for larger version
ID:	100031Click image for larger version
ID:	100032Click image for larger version
ID:	100033Click image for larger version
ID:	100034Click image for larger version
ID:	100035Click image for larger version
ID:	100036Click image for larger version
ID:	100037Click image for larger version
ID:	100038Click image for larger version
    • 14014
    The current 1/72 torpedo manufacturing technique (hollow, cast resin weapon) is too labor intensive. I've got to come up with a better production method. An old idea, but one that seldom came with success -- owing to the high gas leakage rate -- is to cap a length of K&S aluminum tube with a resin warhead and afterbody. Trouble with this method of construction is that the relatively high pressure of the propellant gas (typically 70 psi at room temperature), coupled with the wide thermal expansion rates between aluminum and cast polyurethane resin, stressed the aluminum-resin union to the point where most adhesive would fail and the charge of gas within the weapon would leak away.
    I conducted a series of tests involving a very tight interference fit between torpedo parts, use of RTV adhesive, and a radial crimp to not only effect a strong union between these parts, but to also assure a gas tight union, even during the chilling operation employed to get the maximum amount of propellant into the weapon during the charging operation.
    Here I've made a series of afterbody and warhead blanks to test -- in mass -- the gas tight integrity of these new type gas propelled, 1/72 weapons. I'm also going to study the effectiveness of different stabilizer off-sets to find which one delivers the most stability to the weapon during its run through the water.
ID:	84562Click image for larger version
ID:	84563Click image for larger version
ID:	84564Click image for larger version
ID:	84565Click image for larger version
ID:	84566Click image for larger version
ID:	84567Click image for larger version
ID:	84568Click image for larger version
ID:	84569Click image for larger version
ID:	84570Click image for larger version
ID:	84571Click image for larger version
    • Scott T
      • May 2009
      • 414
      Another crazy idea!
      See attached sketch. Reduction in production machining.
      1) Cast the gas chamber with materials that stays with the torpedo. Make a chamber and exhaust nozzle assembly from a straw
      with end caps of plastic. The nozzle tube is glued into this and placed in the mold.
      2) Pour the resin in one shot mold around the chamber tube assemble. No glueing in plugs and turning to shape.
      3) For the gas nozzle fill the tube partially with RTV silicone (if compatible with propllent) then drill the nozzle area with a drill bit.
      4) cut a hypodermic neele to length and insert through RTV making a precision size orifice.
      Scott T
Name:	torpedo molding.jpg
        • 14014
        Originally posted by Scott T
        Another crazy idea!
        Scott T
        [ATTACH=CONFIG]24250[/ATTACH]
        Not crazy. It's another way to skin the cat. And food for thought, Scott.
        Trouble is machining the resin body to diameter and getting rid of the flange lines -- requires spinning on the lathe followed by putty and primer work. This is pretty much how I manufacture the weapons up to this point. See pictures below:
ID:	84610Click image for larger version
ID:	84611Click image for larger version
ID:	84612Click image for larger version
ID:	84613Click image for larger version
ID:	84614Click image for larger version
ID:	84615Click image for larger version
ID:	84616Click image for larger version
ID:	84617Click image for larger version
ID:	84618Click image for larger version
ID:	84619Click image for larger version
ID:	84620Click image for larger version
ID:	84621Click image for larger version
        Way, way too labor intensive. Best just to make the main-body the aluminum tube and be done with the spinning operations.
          • 14014
          OK. Warhead and afterbody masters done -- check; rubber tools done -- check; cast up and assemble four different type (vary by stabilizing fin off-set) weapons -- check; leak check new weapons -- check.
          Fine. Tomorrow Ellie and I go to the Lynnhaven Dive Center pool to find which type weapons runs the best in the pool.
          Film at Eleven!
ID:	84623Click image for larger version
ID:	84624Click image for larger version
ID:	84625Click image for larger version
ID:	84626Click image for larger version
ID:	84627Click image for larger version
ID:	84628Click image for larger version
ID:	84629Click image for larger version
ID:	84630Click image for larger version
            Hate to throw a spanner in the works, but how hard would it be David to manufacture a longer version of the current 1/72 scale torpedo?
            In my experience, I'd love to have a longer running torpedo. That would need simply more fuel. Sure it won't be scale, but those who use this will tell you these torpedoes don't typically get mounted on the display stand for rivet counters to question. Mine have two states, stored in a box, or in use. When in use - their hard buggers to see too. A longer version would need a longer launch tube, but would not need a re-tooled (larger diameter) launch mechanism.
              State of the Art Nifty Sir!
                • 14014
                Good news, John:
                Just got back from the diver's training pool where Ellie and I did some testing of the 'new' 1/72 weapon. The increased volume within the weapon over the old resin design has resulted in a marked increase in range -- about sixty-feet now. However, I found that I need to tighten up the nozzle throat diameter from its current .014" to .009" as the weapon is too fast and will fly into the air on occasion. Going back to the pool tomorrow with new nozzles and we'll see what kind of range that gives us.
                Increasing the weapon length, means a launcher of comparable length.
                  Good news, John:
                  And let that be a lesson to you Mr. Slater
                  You wonder why your order isn't ready? It's because folks like you dangle carrots like this in front of HWSNBN and off he goes, regardless of order priority, so don't come whining to me because your stuff isn't in the mail!
                    • 14014
                    Damit, Boss! .... stop chasing the customers away!
                      As eloquent and as straight to point as ever Mike. But that is part of the reason why the long term nuts (like me) are in the hobby -Innovation. Indeed this forum success is based on that.
                      David - he does has a point. Its been a long wait. Can you please finalise the order ASAP.
                      Thanks guys.
                      John
                        Thanks guys.
                        John
                        Yes I do! Do what he says Mr. M Digitum Extractum!
                          • 14014
                          OK, Boss.
                            • 14014
ID:	84694Click image for larger version
ID:	84695Click image for larger version
ID:	84696Click image for larger version
ID:	84697Click image for larger version
                              [ATTACH=CONFIG]24345[/ATTACH][ATTACH=CONFIG]24346[/ATTACH][ATTACH=CONFIG]24347[/ATTACH][ATTACH=CONFIG]24348[/ATTACH][ATTACH=CONFIG]24349[/ATTACH]
                              I guess you've finished Slats order then?
