Wet Running Outrunner
  • Bob Gato
    • 826
    I have been converting the GATO to brushless power and have successfully tested the motor and the ESC underwater-so far no detrimental effects noted. and this ESC appears to be VERY waterproof.
    Unfortunately my tub is too short and I ran out of seasonal temperate water-of course all the trimming gets thrown out , as this motor is much smaller and lighter then the brushed version.
  • QuarterMaster
    • Sep 2015
    • 1194
    Bob,
    With all this we've been working on, eventually a water tight compartment can no larger than a cigarette box housing only the RX, BLM and AD2 aboard a simple servo gas boat using 12V SLA's. Regardless of boat size.
    Imagine my 1:48 LA with the only dry area the size of that! Certainly headed that way with my 1:96 boats!!
    "Sub" Ed
    v/r "Sub" Ed
    • QuarterMaster
      • Sep 2015
      • 1194
      Reserving these for the SSRN SEAVIEW.
      Wait till we drop THAT in your pool! the 1 hour three point turn!!
      Yuenhoang Brushless Motor Underwater Thruster 12V-24V CW CCW 4-Blade Nylon Propeller for DIY Underwater Robot RC Bait Tug Boats (1pair CW&CCW)
      v/r "Sub" Ed
      • ffr2608
        • Oct 2009
        • 216
        I like this thruster methodology. Plastic bushings and sealed windings to resist corrosion.
        This T200 comes with a slightly shorter cable and a pre-installed cable penetrator and is a drop-in replacement for the thrusters on the BlueROV2.
        • Bob Gato
          • 826
          A little pricey...and I prefer to be able to spray a couple of shots of Corrosion X or WD 40 into it easily after use ...I could be making a mistake but an under $20 dollar motor and a quick change mount would be my choice. (especially if all you run is clear fresh water)
