Seaview Subdriver vent valve
    Go get 'em, Lance!
  • Lance
    Dave,
    I received the items you sent and have installed them into my Seaview. They work great! I've only tub tested the Sub-driver but it's working better than it has in a long time. Thanks for you help! Now on to other projects, I just got a Revell Gato and Type VII for my winter project and have ordered the Caswell conversion kits. I'll read up on the Cabal Reports and view your how-to discs when they come in.
    Thanks,
    Lance
  • Lance
    Thanks Dave, you've got mail.
    Lance
    I'll get those items to you right away lance. E-mail me your address.
  • Lance
    San Francisco Fun-Run & Seaview Issues
    Dave,
    I got your message on providing an mailing address for the vent valve but your inbox is full. Is there another way I can send you my address?
    I went to the San Francisco Fun-run a few weeks back. Had a great time as usual. I was happy to have some company with other Seaviews this year. Jeff Porteous brought his Teskey Seaview and we got some run time together. I'll attach some pictures. My Seaview was very slow to flood the ballast tank due to the sticky vent valve but she ran well otherwise, except for a troublesome motor that finally quit at the end of the day. I had a couple of spares at home and tried following the instructions found in the Cabal reports provided there. (thanks!) Unfortunately, I ruined both motors trying to replace the short shaft with the longer Seaview shaft. In addition to the vent valve could you also throw in a couple of Seaview motors with the shaft installed? I will gladly pay for the items and shipping.
    Thanks,
    Lance
ID:	65002Click image for larger version
ID:	65003Click image for larger version
ID:	65004Click image for larger version
ID:	65005Click image for larger version
ID:	65006Click image for larger version
ID:	65007Click image for larger version
  • Lance
    started a topic Seaview Subdriver vent valve
    Help! I've had a sticky vent valve on my Seview Sub-Driver for a while now. I would remedy it by removing the vent and stretching the rubber valve and reseal it. That worked until this weekend when I was getting the hardware ready for the San Francisco Fun-Run taking place in two weeks and pulled the rubber valve off the housing. What adhesive is used to secure the two items? Are replacement valves available?
    Lance
