O-rings leaking
  • scubaed1911
    • Jul 2019
    • 45
    O-rings leaking
    O-ring leaking in battery compartment and drive section. I checked rings for cuts and they seem okay. Complete WTC submerged in bathtub with no leakage. After 20 minute run, found water in battery compartment and condensation in drive section.
    What am I doing incorrectly?
    Thanks!
    • 1791
    Thanks!
    Ed,
    Can you put up some photos of your WTC!? That would help to know what type cylinder and caps you have!
