I've done the main spray painting of my Revell Skipjack using Tamiya TS spray cans (Tamiya fine surface primer L base coat TS-29 Semi gloss black for the upper hull, TS-33 Dull red for the lower hull). The Tamiya paints give a nice homogenous satin finish. Masts and other details still need to be done
I would like to use some of the stock Revell kit decals, what would be the best approach to applying & sealing the decals. I understand that the Tamiya TS clear coats (TS-79 semi glass clear and TS-80 flat clear) can attack the decals if applied as wet coats, but it may be able to use these over microscale liquid coated decals with several mist coats.
