Low Pressure Blowers S.A.S. System
  • Monahan Steam Models
    • 755
    I started work on an experimental (to me) WTC that will have a single Vent/Blow ballast tank. I’m looking at using two of the micro air pumps Bob has available on his website.
    My question is, when running two pumps, should each be plumbed separately or can I manifold together their intakes and outlets in parallel? Thanks!
    • 12286
    Plumb them in series (more pressure) or parallel (more CFM's). The analogy to Ohm's-law is almost perfect.
      • 755
      Thank you, that helps a lot!
        • 2748
        Is this going into your hybrid ballast system or a totally different system altogether?
          • 755
          This is for the hybrid ballast experiment.
