Using the LPB pump as an air compressor.
    • 2752
    Can you use the LPB pump to recharge the gas bottle then use it to blow the ballast tank? I know you wouldn't get as many "blow" compared to using Propel but you can refill the tanks everytime you surface.
    • 1777
    You'd need a huge air bottle. You can't use the standard gas backup canister. You'd also need a solenoid or other valve to seal the tube after the pump shuts off. I bet you'd get 1/8 of a ballast tank's worth of air.
    Not feasible with onboard components, I'm afraid, but I like how you think!
      • 831
      Ha-In Groton (Johan) traveled with a 3000PSI scuba tank to refill the accumulator in his 7ft Beast!
        • 2752
        Wow! You could easily put an onboard compressor on that thing.
          • 2752
          Click image for larger version  Name:	image_44617.gif Views:	3 Size:	13.9 KB ID:	143806 Just stumbled across this
          Technology - The knowledge and the equipment you'll need to construct and operate your radio controlled model submarine. Table of contents: - Submerging - absolute basics. - Dive planes. - Model types - static divers and dynamic divers - Model submarine ballast systems - The volume of your ballast tank - Sealing the moving parts
          Was hoping to have a system that fits inside a 2" SD.
          Definitely for bigger boats.
          Maybe (a modified version of) this can be used onboard subs.
          Click image for larger version  Name:	20200924_224638.jpg Views:	0 Size:	38.1 KB ID:	143802
          This video is a quick follow up on the 164OB On Board Air Pump with it being demonstrated in a pneumatic system. We hope you enjoy this video and learn some...
            • 2752
            Did some rough calculation (Boyle's Law P1V1=P2V2) with the 2" SD. To fit the volume air inside ballast tank into the gas canister would require approximately 60-70 PSI. Way beyond the capacity of the snort pumps ( rated to only 15-17 psi).
            You could use a lower pressure but you would need a bigger storage tank. A smaller tank would entail using a more powerful pump.
            Definitely for those with big boat.
              • 12311
              If nothing else, this is a fine thought exercise.
