Nice Turn Radius!
That's definitely the way! Thanks..it doesn't appear to take much throw on that long prop shaft to be effective..nice! -
Or, you can gimbal the propeller. In this example I'm not only swinging the propeller to increase the yaw rate, but also swinging it in pitch, thus eliminating the 'un-scale' stern planes often seen on r/c models depicting the Disney NAUTILUS.
Here's a video of the NAUTILUS employing the two-axis propeller gimbal illustrated above: https://youtu.be/cwS6o4jsxoU https://youtu.be/kOO_sz6Sh7U
DavidLeave a comment:
Not exactly scale, but effective. If you weren't a purist or detail snob, you probably would never know. I always thought it was pretty ingenious.
I favor the clear rudder extension. Invisible in the water and removable in seconds when you're ready to display...
BobLeave a comment:
Nice Turn Radius!
Does anyone know if the split rudder is unique to this model ? If you watch between 3:58-4:28 minute points its quite notable that the sub turns very well without any rudder extension and looks period scale-the rudder is a little like a nozzle on a tugboat...well done! (video courtesy DominicM-RCG)
Tags: None
