Randy,
That would work just fine, but typically use bullet connectors embedded in the end cap. That way you can just unlplug the motor to completely remove it for replacement, maintenance or upgrade.
Water proof Servos and motors.
Yes, extensively. I and many others have successfully waterproofed standard servos, and I've used the new "waterproof" Hitec servos to good effect as well. Brushed motors can run wet, though they require additional maintenance and the life will be reduced. Brushless are perfectly happy in the wet, but again, you have some post-run maintenance for a full lifetime. My new cylinders feature brushless in the wet.
As a point of thought, you've eliminated a linkage seal, but now you need to deal with an electrical seal. Certainly doable, but bear that in mind.
In your book Bob you mention the brass rod through the bulkhead for the servos would that method work for the motor or is the current to high?Leave a comment:
I've used this product on my truck servos, receivers and LED circuit boards to waterproof them
https://jimsbearings.com/products/he...erproofing-kitLeave a comment:
Great replies, many thanks. Been using the big hitec waterproof on some other projects yet good to know others are as well.
Regards,
GregoryLeave a comment:
This guy doesn't even use a WTC. He just seals his electronics with nail polish.Leave a comment:
Quick question has anyone experimented with water proof servos and motors? Thus limiting the WTC units to RX's and pump systems and some water proof connectors.
Regards,
GregoryTags: None
