ABS pipe
  • gantu
    • 361
    ABS pipe
    I am looking for abs pipe 5 1/4 inch ???
    Regards Gantu
    • 331
    • Scott T
      • May 2009
      • 378
      Why not PVC which you could slice and glue back together longitudinally.
      Guessing you want 5 1/4" outside dimension.
      5" schedule 40 PVC is 5" I.D., 1/4" wall so 5 1/2" O.D.
      • gantu
        • 361
        Thank you Scott yes outside diameter 51/4.
        Regards Gantu
        • Scott T
          • May 2009
          • 378
          They say you can solvent weld ABS plastic with MEK.
            • 831
            Be careful that you don't buy that MEK substitute that they sell in the big box home stores and the hardware stores... Real MEK is hard to come by ... Good old-fashioned model airplane glue in the tube or liquid in the little jar would be my choice.
