British X-Craft Build
    • 1768
    This is going to be a 3D printed build of the World War ll midget submarine X-Craft. It is a 1:24 scale derived from STL files from Nautilus Drydocks!
Name:	BRITISH X-CRAFT 2.jpg
ID:	169232Click image for larger version
Name:	BRITISH X-CRAFT 1.jpg
    I will be using Dremel white PLA and using my Dremel 3D40 DigiLab printer.
    "Firemen can stand the heat."
    • 2735
    Are the side charges printable as separate pieces or integrated with the hull? Would be nice if they were separate as you can model the boat with or without them. Also a good way of covering the longitudinal seam.
      • 1768
      Romel,
      The side charges are a separate print and piece. I am building this model to set for RC operation so the hull will separate along the longitudinal with a top and bottom hull. Just like the left hand photo above.
        • 2735
        Surface runner or dive capable?
          • 1768
          If it were me, I'd make it a dynamic diver. These boats had virtually no freeboard anyway. It would make an awesome, simple and fun pool sub. I'm betting maneuverability will be excellent.
            • 2735
            I have the 1/35 scale kit from Merit similar to this Click image for larger version
ID:	169250 (screen grab from Youtube)
            Will cut the hull similar to Rob's boat.
              • 1768
              Romel,
              I have to go with what Bob said about this boat! I am going to go with a dynamic diver for sure!
              "Firemen can stand the heat.:
                • 1768
                I have downloaded all the STL files and I have the parts listed on my print list.
                Click image for larger version  Name:	BRITISH X-CRAFT 3.jpg Views:	0 Size:	56.7 KB ID:	169552
                I use these check sheets on all my 3D printed submarine parts list so I can keep track of what has or has not been printed out! I am waiting for my white PLA from Dremel and then we can start the build.
                  • 1768
                  Starting to make some headway on the British X-Craft!
Name:	BRITISH X-CRAFT 4.jpg
ID:	169666Click image for larger version
Name:	BRITISH X-CRAFT 5.jpg
                  Just finishing up the last bottom section. From here I will move onto the top sections.
                    • 1768
                    More headway on the X-Craft!
Name:	BRITISH X-CRAFT 6.jpg
                    The main hull sections are complete! Moving onto the tanks next in the printing process!
                    • Bob Gato
                      • 826
                      Great subject lots of character!... Thank God for blue tape.
                        • 1768
                        Last night I finished printing all the parts required for the British-X Craft!
Name:	BRITiSH X CRAFT  7.jpg
                        Very good STL files (purchased from Nautilus Drydocks) the entire printing process went very well.
Name:	BRITISH X-CRAFT.jpg
                        I have also made some progress on my 2.5" OD WTC. This boat will be a dynamic diver with no ballast system. Should be an excellent running boat for the pool.
                          • 2735
                          Any plans for deployable side charges ? ;- D
                            • 2735
                            Permanently attached or removable (with magnets)?
                              • 1768
                              I have the hull sections on the X-Craft all glued up, including the side charges.
Name:	BRITISH X-CRAFT 7.jpg
Name:	BRITISH X-CRAFT 8.jpg
                              The stern section will be attached later after all the control surface linkages and the propeller shaft has been installed. Leaving it off at this point will allow better access to the linkage installations.
