About 10-13ish years ago when I built Skip's Marlin, I saved my nickels and dimes to buy a lathe from Micro-Mark. I picked it up directly from MM to save on shipping. Machining was something I wanted to get into at the time. Now, some of the things you would make on the lathe you can make with 3D printing. I don't have a 3D printer, yet, maybe in the future, but I'd like to start using the lathe more. Haven't powered it on in the past 10 years. The only time I used it, when I first got it, bought a large bolt to practice on, see pic below. I don't have much tooling, only what you see below. I bought blank bits that I had to put an end on myself, which I did, and was a pain in the butt. I think I need to buy a more variety of bits. So I need some guidance were to go with this. David said at Subfest, stick something in the lathe and just use it. Of course the best method to learn is use it, maybe make some mistakes along the way and learn from that.
I know I have some of the terminology wrong. I'll eventually get it right as I learn.
A few pics of what I'm working with.
All of the bits the bits that I have.
These are blanks.
Centering bits.
Measuring tools.
These are parts that came with the lathe. The gear set I think is for cutting threads. Have to read the manual.
Centering tool and spares jaws.
Not sure what this is. Will refer to the manual.
The manual.
And reading material. Looks kinda dated.
Some of the stock I can use to practice on. Aluminum.
This is the bolt I practiced on when I got the lathe.
Plastic rod.
This is the bit I ground myself on the HF grinder I have. The grinder i have is too lightweight for this kind of work.
So besides chucking something up and using it, what additional tooling should I get? I'm sure I need more types of bits and other stuff. What advice do you have?
These are blanks.
Centering bits.
Measuring tools.
The manual.
Plastic rod.
