I have a question about the new Nautilus Drydock 80mm WTC on/off switch wiring?
I already have installed the 70mm WTC in my 1:96 scale Alfa sub and it has the same on/off switch. Well, I somehow miss wired that switch to power and burned it up!
Could someone post up a wiring diagram as to how this switch would be wired from the 3 cell 11.1 battery pack to the switch and to the Viper 10 ESC? I must have wired 100's of ESC's when I was flying RC airplanes, but for some reason this switch is throwing me!! Thank you in advance! I know this is simple wiring, but the 80 plus rears are catching up!! :-))
AS A SIDE NOTE: I have seen Bob Martins new video on the 80mm WTC wiring! It does not show a wiring diagram on the switch, I could not see how it is actually wired!
