"The best part is no part", Elon Musk
    • 12256
    More and more devices (ESC, some servos, motors, some batteries, and fail-safe devices come to mind) are encapsulated or housed in their own watertight enclosure.
    The ideal wet-hull submarine is one without a WTC, SD, module, box, or compartmented lower hull or other such dedicated watertight enclosure needed to house things that must be kept dry.
    I'm not the first to make this observation. However, we are getting closer to the day when all devices needed to animate our r/c model submarine can operate in the wet.
    Imagine how much simpler installation, maintenance, and mission checks will be with such a model! And you eleminate the most expensive element of the model submarine.
    Kevin McCloud, call your office!
  • QuarterMaster
    • Sep 2015
    • 1194
    Preaching to the choir!
    Less IS more.
    v/r "Sub" Ed
    • KumaDog
      • Sep 2021
      • 36
      Agreed.... but they still need to connect to one another.
        • 12256
        Clear, flexible conduit hoses between wires and devices.
        • Ken_NJ
          • Sep 2014
          • 745
          My Marlin has a spinning radar. The micro-motor is housed in a plastic housing. The wires exit the bottom and go thru a plastic flexible tube which is open to the water. I know this works well as the Marlin was lost underwater for nearly 8 months. As I was building the boat I tested this in the pool and the water hardly compressed the air. This is good as long as the boat remains upright.
          The plastic case I made for those resistors did not hold up. The etched circuit board was corroded. Pulled out the circuit board and went another route with the wiring of the LED's and all.
          • Schmitty1944
            • Mar 2021
            • 108
            If nothing is perfect the closer you get to nothing the more perfect it is.
            Jason
              • 1149
              Ken,
              Your stuff is first rate. Up there with the best. I wish I was as smart as you and the rest. David, Bob, Steve, etc.
              Of the 40,000 men who served on German submarines, 30,000 never returned.”
                • 12256
                Originally posted by Das Boot
                Ken,
                It ain't smarts. It's tenacity! Guy's like Ken, Nick, Bob, me and others -- we can't quit till the jobs done right. A trait we don't see too much of these days.
                  • 1149
                  If I see something done once, I can duplicate it. It’s coming up with it on my own. I’ve done it a couple of times, but I’m no engineer.
                    • 12256
                    Coming up with it on our own. No, Casey. We don't do that. Everything we do is a variation on what others did before us -- it is, if you will, all a variation on the 'wheel'. All we do today is refine and redefine what was already discovered/invented.
                    No Engineer, but a ****ing good Mechanic
                    • Monahan Steam Models
                      • 755
                      Well said. Nothing I do is original. Everything I’ve done has been done before me. The stuff I make is to reflect as close possible the work that was done before me. If you look at my torpedo launchers closely they follow the same basic principals as the originals. Strike fame from your ambitions of being original and be humbled by the work of those that have come before you
                        • 1770
                        Well stated Nick!
