Not sub related but feeling dated
  • Monahan Steam Models
    • 755
    I was searching the interwebz this afternoon for some miniature marine steam engine info I recalled running across years ago. In my search I ran across an old informational YouTube video I did 12 years ago for one of my US dealers, filmed out back at my old machine shop. It was for one of the Heron steam plants I designed and used to manufacture in-house and sold all over the world. I both miss and don’t miss those days. I always joked with whomever asked how it was all made, “i use the worlds most advanced technology to make antiquated technology”
    Purchas this engine from http://www.ministeam.comMiniSteamThe Monahan Heron, is a double acting, slide valve, twin cylinder 3/8 in bore, 3/8 in stroke steam ...
    • 2753
    Beautiful work.
    How about putting one of those in a submarine? Click image for larger version
    • Halcyon66
      • Oct 2021
      • 28
      Great reference site, spent some time going though it today.
      Regards,
      • Bob Gato
        • 831
        https://m.youtube.com/watch?v=Md0lZRZVPIY
        You are an amazing Dude, Mr. Monahan!
        • Sam Victory
          • Sep 2021
          • 391
          The HMS K class submarine is a steam-powered submarine, driven by steam turbines at the surface, so it has a high surface speed. The smoke is emitted from the thick chimney when running on the surface, when submerged, the chimney can be retracted into the boat and switched to electric propulsion.
ID:	154652Click image for larger version
ID:	154653Click image for larger version
          Plans:
Name:	K class sub.jpg
            • 755
            Beautiful work.
            Thank you!
            In regards to steam in a submarine like the boat referenced above, it is definitely possible to do in a scale model but it would probably be more of a hassle to service and operate the model then it is worth in my experience
              • 755
              How ironic! Today I was just looking at some of your product designs!
              This is the Krick Alexandra that I was considering to build! And it looks as if it they used one of your steam systems! I am getting a little burned out on submarines, so I thought I may give steam powered boats a go! Looks like a great hobby!
              Rob,
              The Krick Alexandra would be a great choice to start with but if I may suggest another option, the Krick Anna would be another great choice. Just like building submarines, with steam boats it best to keep them simple. The engine and boilers in the pictures you posted were not made by me.
              If you want your first steam boat build to be fun, successful and easy to operate then I would say the best combination in my opinion would be a Krick Anna with a Chedder Models Pintail Vertical steam plant. The Pintail steam plants are long out of production but they come up for sail every so often on flea bay.
              Like submarines, steam boats are not a cheap hobby if you want to build one that works well and is a solid dependable performer.
              For RC steam boat models, the best boilers are heated with butane/propane burners. In this category not all boiler manufacturers are equal. Steer clear of the overseas offerings.
              For engines, simple single cylinder designs are not self starting or reversible. Two cylinder engines that have 90 degree crankshaft throws and are of a double acting design (meaning steam is admitted and exhausted on both sides of the piston) are usually self starting, reversible and are controllable proportionally in both directions.
              The Krick Alexandra requires a small light weight vertical boiler like the Pintail that were made by Cheddar Models. Larger boilers like the ones shown in the pictures you posted will make the Alexandra very unstable and tippy. I suggest a model like the Anna because the length to width ratio makes for a very stable platform that will have a great turning radius if you wish to operate in a small pool and still have a model that you can take to a larger pond or lake and be able to tolerate rougher seas without being swamped and sinking.
              Regards,
              Nick
                • 755
                Thanks Bob!
                  • 755
                  Plans:
                  Very cool!
