Indonesian submarine goes missing
Tags: None
Oil spill found at last known position.
https://www.channelnewsasia.com/news...drill-14665862Make it simple, make strong, make it work!Comment
Possible debris from sunken Indonesian sub found
A dedicated SOSUS-type system has the capability to detect LOS signals, but are primarily aligned for contacts in more adversarial detection zones and are better suited for narrowband (discrete tonals) frequencies.. That being said, there are seismic sensors capable of detecting broadband events within that area of the world.
The US isn't about to geo-locate and risk compromising a valuable capability when the general area is well known and it's only a matter of time before the wreckage is found.Comment
Sunken Indonesian sub found https://youtu.be/sLVMe0F2hS8Make it simple, make strong, make it work!Comment
An underwater robot equipped with cameras reportedly found the submarine at a depth of 2,750 feet, far deeper than the German-built KRI Nanggala 402's collapse depth — the point at which the hull could no longer withstand the water pressure — of 655 feet. It's still unclear what caused the submarine, which had been in service in Indonesia since 1981, to sink.
“Of the 40,000 men who served on German submarines, 30,000 never returned.”Comment
Rest in Peace.
I'm surprised how quickly the local authorities ruled out human error as the cause of the sinking.Last edited by redboat219; 04-25-2021, 11:01 PM.Make it simple, make strong, make it work!Comment
