Announcement
Forum rules and expectations
See more
See less
1/72 Gato Conversion Info
  • Filter
  • 1/72 Gato Conversion Info
    Got back into working on this beastie, and, so far, things are going pretty well. Today will be spent on getting the shafts and struts installed. I know enough about that to be semi-dangerous. I was wondering if there is some place where I could go, or if someone could perhaps send pictures of; the methods for attaching the main deck hold-downs, the bow planes torque tube actuator (at the aft end), and how to do the torque tube fabrication and mounting? I have ideas and pictures in my noggin, but I would like to be successful in this endeavor, so I thought I would consult the experts!! BTW- before someone sends me off to Cabal Reports, a lot of what I'm after isn't in there.
    Thanks,
    Bill
  • #2
    Resident Luddite
    • #3
      Most excellent, sir!! A goodly bit of just what was needed! You have made this old knuckle-dragger a happy camper!! There is hope!!! Got anything that shows mounting of the head valve, and routing/mounting of the torque tube, going toward the bow??
      • #4
        Let me dig into the vault-of-terrible-secrets and let's see what we'll see...
        But, start with this: https://youtu.be/INq9OqWFJys
ID:	148366Click image for larger version
ID:	148367Click image for larger version
ID:	148368Click image for larger version
ID:	148370Click image for larger version
ID:	148371Click image for larger version
ID:	148372Click image for larger version
        Resident Luddite
        • #5
          Thank you!! Significant progress has been made! The pictures have made a world of difference in that regard! You are my hero!! :)
          • #6
            Is the bow planes bellcrank (w/magnets) meant to pivot on the axle shaft, or does the whole assembly pivot in the "holder" rings that are glued to the hull?
            • #7
              Either one or both, Bill. The magnets keep the bell-crank centered on the shaft regardless. You want minimal torque drag here.
              Resident Luddite
              • #8
                Ok! Thank you, sir!! It shall be made so!!!
