Most Common Electrical Connector Used In R.C Submarines
  • george
    • Dec 2010
    • 727
    Hello
    Like the title says. I was wondering What the Most Common electrical connector is that is used to make electrical connections in R.C submarine electrical systems? I know of direct hard soldering but what is the most common connector used and why?
    Thanks in advance for your replies.
    George
  • george
    • Dec 2010
    • 727
    Thank You for your reply and lessons. Question about Deans connectors. How do you know if you have the real Deans connector or a cheap fake one from china? I heard from some speed racers friends that there a lot of fake Deans out there and they fail frequently on them.
    Is that an issue for R.C sub use OR is it because the racers draw such Large current demands on the Lipos that the fake Deans melt under load???
    • george
      • Dec 2010
      • 727
      Ah O.K then. Thanks for the lessons and your time.
      • george
        • Dec 2010
        • 727
        Sorry for got to ask you about your small servos. Are they metal geared OR nylon geared?
          • 1777
          Some additional input on this. I also use mini-Deans (which are about half the size of traditional Deans), and XT-60 and XT-30. All are great connectors.
          The standard servos in our Subdrivers are nylon gear.
          • george
            • Dec 2010
            • 727
            Thanks for the update.
            • cheapsub
              • 187
              Worse connector setup, old Airtronics servo connection, have the power wires in opposite of everybody.
              In the old days the racers just solder the connection.
              if the connector turns black, something goes wrong with the system.
              convince! stick with your setup. Little Dielectric grease on the contact goes a long way.
              I still have some dean's connector , 100% makes in china. Wants some .
              still don't get this, war story,
              people managed to push in xt60 connector the wrong way. Never on a Dean's.
              Got some stash of xt60, I could spare some, let me know.
