What sort of run time are the new msd direct drive units on a 3000ma pack driven at a moderate speed are expected ?2-3 hours?
Run time
Tags: None
Who is John Galt? -
So many factors that can affect that. A Skipjack is going to take a lot less power to push through the brine than a Type XXI. Free running the draw will be minimal, most brushless motors I have pull no more than a few watts free running, and then they load up according to the prop size and RPM you run them at. Quite a brute of a motor in those new units, so you shouldn't have any issue's with power,Comment
