Gas bottle hose
  • secrtwpn
    • Feb 2012
    • 182
    Gas bottle hose
    Today, I was filling the gas bottle (following the instructions) with the air brush propellant. As soon as I attached the can to the Shrader valve, the vent hose blew off. This is not the first time its happened. What am I doing wrong????????
  • secrtwpn
    • Feb 2012
    • 182
    ....................closer inspection of the instructions compared to mine shows that mine does not have the fitting attaching the hose to the bottle......
    • secrtwpn
      • Feb 2012
      • 182
      I have one of those parts, but it appears to be too big a diameter for the bottle. Is it soldered on?
        • 1777
        I'm having a really hard time envisioning the parts you're referring to. I assume you're talking about the emergency gas backup, correct? The hose is blowing off the top of the reservoir when you try to fill it? That's really weird.
        • secrtwpn
          • Feb 2012
          • 182
          I think I figured it out. I slipped the fitting over the hose, attached the hose to bottle, and slid the fitting over hose and the nipple....... Click image for larger version
            • 12289
            Bingo!...…………………..
            • Scott T
              • May 2009
              • 378
              You got a Bingo!
              • secrtwpn
                • Feb 2012
                • 182
                ..........................where can I collect my winnings???????
                • QuarterMaster
                  • Sep 2015
                  • 1198
                  Why, from AOC of course!
                  v/r "Sub" Ed
