submarine on a selfi-stick
    • 12288
    Go to the bottom of the page for this video. Fantastic concept and beautiful execution.
    https://www.rcgroups.com/forums/show...ur-Subs/page18
  • Bob Gato
    • 831
    I couldn't figure how the camera was attached -yes the tether attached to the sub's belly and goes straight down(sometimes it is seen bouncing off the bottom causing the sub to shake) but the camera angle is up at waterline level-does the camera float and is tethered to a weight that drags the bottom and is pulled by the tether from the bottom of the sub?..If so , the camera should shake as its weight is also dragged along the bottom?? Or is the camera weighted for neutral buoyancy if so the tether should go straight back and not down.
      • 12288
      Or, the camera body is also on a vertical shaft and bearing and has 'tail-feathers' to keep it pointed at a near zero angle-of-attack to the water flow. Back the boat down and you get a bow shot. Put the boat in a tight turn, and as its skids, the POV starts to look at the inboard side of the turn.
        • 2749
        Actually your title should be submarine selfie stick.
        I think what he did here is he attached a length of rigid wire underneath the hull which was free to rotate around the sub. He then attached the camera to the end with some flotation foam to make it neutrally buoyant and not affect the sub's trim. I'm trying to ask him for some photos of the setup.
        Here's a test video https://youtu.be/KsW_wrFgSTg
          • 12288
          I'm amazed at this guys work. And thanks for that video. Most instructive.
            • 2749
            He has a blog.
            Here's the link for this particular sub https://blogs.yahoo.co.jp/wat_rcair/folder/1275272.html
            Click on libray to see his other projects.
              • 1777
              That is a really, really great idea, though I like the towed camera idea better. The thing about the selfie-stick, though, is that it offers a bit of a failsafe against crashing into the bottom. On the downside, I could see it hooking all manner of weeds and such as it moves through them...
              • Bob Gato
                • 831
                If you go to frame 1:10 you can see a reflection in the tank side when the sub is turned and it shows a little more of whats under the sub...
                • Bob Gato
                  • 831
                  I love his engineering-here's one of my favorites- An amazingly simple static dive with snorkel..
                  He also does the capacitor run mini torpedos
                    • 2749
ID:	131558 Here's a diagram.
                      • 651
                      Start of the blow, is he compressing the ballast tank by sucking out of it? Not sure how it starts to go ip before the snorkel breaches.
                      • Bob Gato
                        • 831
                        Bottom R/H drawing shows snorkel check valve open and thruster drawing water in thru snorkel tube(note diameter is same size as thruster bore) and forcing it out the bottom of the sub driving it upward. The calibrated trapped air (determined by the air vent tube) keeps the sub at a positive or almost positive buoyancy. And the sub rises..Brilliant! especially for really small subs..
                          • 2749
ID:	131582 Photo of actual thruster and snorkel with check valve.
                          • Bob Gato
                            • 831
                            Nice-the guys on RGC have tried to ask him for the "secrets" and so far none-Is that check valve and thruster (why doesn't the program recognize thruster as being spelled correctly?) your's or his? That valve depends on weight to swing it closed?
                              • 2749
                              Here's another one of his check valve. Note the weight near the hinge point. Click image for larger version
