Hello
I have a build project that is NOT a submarine BUT I need some advice from here. I have a tracked vehicle build that is both land and water capable. It is a water surface runner but the the drive shafts go through the hull to the track sprockets. How do I seal that shaft so that water will not find it`s way inside and still have smooth shaft rotation to drive the sprockets?
Pictures work best for me.
Thanks in advance for your help.
George
George
