Snort System
Okay, I'll give it a try. I was afraid a hose may come loose and pump the battery compartment full of water, doing it that way. :( -
Bad idea!!! You get any shavings into the ports and they get at the check-valves within. Game Over!I moved the 2 air-line tubes to forward-bulkhead and installed and sealed the power-switch but when connecting flex-tubing between forward-bulkhead and snort-pump I found that the pump's inlet and outlet ports are larger than brass-tubing provided in bulkhead, (flex-tubing did not fit pump).
So I'm thinking about drilling out the pump-ports slightly and CA gluing some short pieces of brass-tube inside the pump ports to reduce diameter and to lengthen them, since the pump ports are also very short?
Is that the best solution?
Heat a 3/32" diameter brass pin and stick it momentarily into the end of a piece of flexible hosing, repeat till you enlarge the inside diameter of the end of the flexible hose till it will fit over the nipple of the LPB compressor with just enough interference fit to assure it stays there -- experiment first on a discarded piece of flexible tubing.
David,Last edited by He Who Shall Not Be Named; 11-17-2008, 01:31 PM.Leave a comment:
Is that the best solution?Last edited by toppack; 11-17-2008, 12:51 PM.Leave a comment:
Good plan.I was afraid you were going to say that. :eek:
The aft compartment is Completely Full already, no room for pump there. I plan to put the snort pump in other end of tube with battery. So I need to somehow Move those 2 brass tubes to the other end of SD ??? ;)
It appears the tubes in motor bulkhead are not easily removeable? So I'll probably just plug them and drill holes in battery bulkhead and seal in more tubes for pump access.
I think that would be easier than trying to run tubing from one end to the other (inside) and still be able to connect it up.
I need to drill a hole in it for power-switch anyway, so what's a couple more holes gonna hurt. :D
David,Leave a comment:
I was afraid you were going to say that. :eek:The 2 brass tubes through the rear motor bulkhead allow these tubes access to and from the pump.
I need to drill a hole in it for power-switch anyway, so what's a couple more holes gonna hurt. :DLast edited by toppack; 11-16-2008, 11:48 AM.Leave a comment:
There are 2 tubes on the low pressure blower/pump. One goes to the ballast tank to put air into it, the other runs from the Snorkel. The 2 brass tubes through the rear motor bulkhead allow these tubes access to and from the pump.Leave a comment:
I have another question about the Snort pump. I'd planed to use a 9.volt battery but I just realized the pump is a 12.v pump.
Will the pump, operating at 9.v (probably around 70% efficiency) be enough air volumn to do the job?Leave a comment:
I certainly need it, because I still can't firure out the purpose and need for the 2 airline tubes going thru rear end of the SD ??? The Snort pumps air into the center ballast chamber doesn't it?Last edited by toppack; 11-15-2008, 12:20 PM.Leave a comment:
And you are absolutely right! There is no list! Darn!
We'll have to fix that. Now, I'm in Florida until Tuesday, so I can't do anything about this until I return to NY.
I have some 1/8" brass tube and I think I have some plastic tuning I can send you.
All you need to to is insert the switch connector into the receiver and then connect the pump to it. 2 holes need to be drilled into the rear end cap and the brass tube inserted there so it sticks out about 1/2" either side. Then the plastic pipe is connected to them.
Email me your name and address to mike@caswellplating.com so I don't forget please. I don't have access to that here in Florida.Leave a comment:
I could not find a system components list anywhere. I naturally assumed the system included everything Pictured with the pump, on snort-system webpage. That parts list should be added, if it's not there.
Thanks,Leave a comment:
