Not sure if they'll fit. Not sure why you guys are having issues with o-rings though, but they should run wet, not dry on the bench. Also use PTFE grease or cooking fat on silicone seals, avoid mineral or silicone based greases.
https://www.aliexpress.com/item/1005005196469534.html?spm=a2g0o.productlist.main.1 .5001j4Hfj4Hfcu&algo_pvid=eda2351e-921f-47d1-aa7a-d727bbef8ca3&algo_exp_id=eda2351e-921f-47d1-aa7a-d727bbef8ca3-0&pdp_npi=4%40dis%21GBP%211.35%210.93%21%21%2111 .7 9%218.13%21%40211b61a417368745404135228e5fe0%21120 00032098470506%21sea%21UK%210%21ABX&curPageLogUid= G6JeMdlBbjUo&utparam-url=scene%3Asearch%7Cquery_from%3A
R&R CYLINDER U-CUP SEAL CONVERSION
I used standard 1/8" cup seals. Ideally you'd use a 4mm seal. Engel offers them, but I didn't want to wait or pay overseas shipping. I just ordered some standard 4mm nitrile seals. I think they'll work much better.Leave a comment:
Bob, or anyone, what size u-cup seals were used in " The RCSubGuy UnPacks Some EPIC Subs and Gets a Scottish Flu" video?
Tags: None
