LOS ANGELES class Sub on Scale 1/81 (I thnik?)
Marius
Post your problems here, there is certainly the quality of modeler here to help amongst the other chaps, they have certainly helped me , but obviously pictures will help.
PeterLeave a comment:
You are Absolutely Right PETER .
It was guest a small problem witch I experienced , among many other wheel follow .
MARIUSLeave a comment:
Marius pictures would help, but some where you will find info on Mr M's D&E 1/96 Skipjack kit/build. I would imagine that he had these problems and he definitely will have overcome them, a 1/96 skipjack is a tiny beast compared to a 1/81 LA.
Not much work these day because I'm stuck with a problem :
- the distance between the steering rudders axle and depth rudders axle is very small and do not know how to manufacture coupling rudders ....
- because of that I can't get a left / right rudders movement necessary for the turn submarine and no movement up / down for dive planes ,
The distance I took it form the drawing and scale distances table , but doesn't seems to be right .
May be You can give me some advices .
These Pictures :
http://postimg.org/my.php?gallery=5bo8sp2o
MARIUS
P.S = if I put only the link , nobody is going to look at pictures becouse are a lots ! .
MLeave a comment:
These Pictures :
MARIUS
P.S = if I put only the link , nobody is going to look at pictures becouse are a lots ! .Leave a comment:
HELLO ,
I don't know what is happening to my posts !?.
Where are the OTHER 14 posts with pictures ?!?!?! .
Way is taking so much to be published ?!.
MARIUS
P.S. to day March / 23 / 2015 , 11.50 Est European Time . GMT +2 .Leave a comment:
