Bronco Type XXIII by Ken
    Going with the top hatch or with Manfred's front-back hull separation for WTC access?
    • Ken_NJ
      • Sep 2014
      • 1006
      #62
      Manfred's hull hold together technique and David's deck hatch technique.
      • Ken_NJ
        • Sep 2014
        • 1006
        #63
        Something that I missed will go here when I get to it.
        • Ken_NJ
          • Sep 2014
          • 1006
          #64
          I neglected to take pictures of doing the same with the aft section. Here are both sections 'bolted' together.
          • Ken_NJ
            • Sep 2014
            • 1006
            #65
            Radial Joint
            With the forward and aft sections bolted together, the deck area is pretty floppy. I added another tab with machine screw to hold the forward section together. This is a temporary bolt.
            The aft section slides over the forward section. I used backlighting to highlight the joint where the aft section slides over the forward section if they were to be glued and marked the end of the joint.
            Acrylic strips were cut to width and edge finished (so it looked nice).
            A heat gun (Harbor Freight) was used to heat the acrylic to get it to shape.
            The soft heated strip was pressed into the hull to get the shape. It required multiple heat sessions to get it right.
            Both sections ready for trimming and install.
            I used my Laser/Engraver to cut three templates the diameter of the sub driver.
            Estimating the hull cut and placement of the sub driver template.
            I moved the hull deck cut upwards. As long as the SD is below the waterline, but lower the better. This is just estimating at this point. The lower is probably better so there is more room for foam in the upper area above the SD. Notches were made where the cut will be so that when the cut is made I don't encounter that inner wall making difficult to make the cut with the Exacto knife.
            • Ken_NJ
              • Sep 2014
              • 1006
              #66
              Hull cut preparation
              The forward and aft sections were joined at the central radial joint with three 080 machine screws on each side. In the end, the hull sections lined up perfectly.
              Click image for larger version  Name:	A_IMG_9281.jpg Views:	0 Size:	51.5 KB ID:	188750
              Click image for larger version  Name:	B_IMG_9282.jpg Views:	0 Size:	49.8 KB ID:	188749
              Click image for larger version  Name:	C_IMG_9283.jpg Views:	0 Size:	51.0 KB ID:	188753
              Using the mark previously made at the end of the previous post, it was transferred to the outer part of the hull. I'll be using an angle piece of aluminum to make the cut line, and be using it to make the actual cut. Very fortunately, this hull is the same flatish shape most of the length of the hull, not like modern cigar shaped hulls.
              Click image for larger version  Name:	D_IMG_9213.jpg Views:	0 Size:	51.6 KB ID:	188755,
              Click image for larger version  Name:	E_IMG_9214.jpg Views:	0 Size:	52.7 KB ID:	188752
              This curved section will require using a different method to get the cut line.
              Click image for larger version  Name:	F_IMG_9215.jpg Views:	0 Size:	53.3 KB ID:	188754
              Click image for larger version  Name:	G_IMG_9216.jpg Views:	0 Size:	52.4 KB ID:	188751
              The bow section was easy with this flexible ruler.
              Click image for larger version  Name:	H_IMG_9285.jpg Views:	0 Size:	51.9 KB ID:	188756
              Out of order picture. The aft section.
              Click image for larger version  Name:	I_IMG_9287.jpg Views:	0 Size:	51.0 KB ID:	188759
              The more difficult aft section. Note that I located the cut line going through a less conspicuous section of the hull feature in the lower right. I did this where all the cuts would be.
              Click image for larger version  Name:	J_IMG_9286.jpg Views:	0 Size:	49.9 KB ID:	188758
              Thats it for laying out the hull cuts. Next up is glueing the deck area.
                • 14006
                #67
                Methodical, logical, exacting work, pal. You're taking us all back to school.
                  • 1658
                  #68
                  Nice progress Ken, to marry both ways David and I used will be very usefull in the future, keep going
                    For the curved section of the hull you could use an old tape measure as a flexible guide
                    • Ken_NJ
                      • Sep 2014
                      • 1006
                      #70
                      Thanks David and Manfred.
                      Romel, the tape measure may work but for me it is too flexible and unruly and difficult to manage. The 2 inch wide flexible ruler is much more manageable in this instance, I used it before on other models and it works well.
                      • Ken_NJ
                        • Sep 2014
                        • 1006
                        #71
                        Apply solvent to the deck joint
                        Before cutting the deck from the hull, the deck halves needed to be joined together. Using the Weldon 4 solvent and a brush, the solvent was applied to the deck seam and the sections were manually squeezed and aligned so that there was a minimum deviation between the sections.
                        Solvent was not applied forward of the bow cut line.
                        Nor was it applied behind the aft cut line.
                        And the solvent was not applied below the horizontal lengthwise cut line.
                        After letting the solvent set overnight, the joints were sanded with 220 and 400 grit sandpaper. This will be further sanded prior to painting.
                        • Ken_NJ
                          • Sep 2014
                          • 1006
                          #72
                          Cutting the deck from the hull
                          I positioned the cut below the horizontal weld lines so that when the filler piece is added, it is added to the hull section, and sanding the filler piece will not impact the weld lines on the upper deck section.
                          Double sided tape was applied to the hull.
                          Click image for larger version  Name:	A_IMG_9315.jpg Views:	0 Size:	54.7 KB ID:	188826
                          The aluminum angle was applied to the double sided tape. The tape was wide enough for both legs of the angle, holding it solidly in place.
                          Click image for larger version  Name:	B_IMG_9325.jpg Views:	0 Size:	49.6 KB ID:	188830
                          The Exacto blade is 20 thousandths wide. Good to know how wide the cut will be.
                          Click image for larger version  Name:	C_IMG_9319.jpg Views:	0 Size:	54.3 KB ID:	188825
                          The back side of the Exacto knife was used to score against the straight edge. I kept the knife as close to being parallel to the waterline as I could.
                          Click image for larger version  Name:	D_IMG_9316.jpg Views:	0 Size:	55.0 KB ID:	188829
                          Click image for larger version  Name:	E_IMG_9317.jpg Views:	0 Size:	54.2 KB ID:	188831
                          Yup, about right. Will use a 30 thousandths filler strip.
                          Click image for larger version  Name:	F_IMG_9321.jpg Views:	0 Size:	49.4 KB ID:	188824
                          First cut. Straight and perfect.
                          Click image for larger version  Name:	G_IMG_9323.jpg Views:	0 Size:	56.7 KB ID:	188827
                          Click image for larger version  Name:	H_IMG_9324.jpg Views:	0 Size:	56.0 KB ID:	188828
                          For the more difficult turn of the hull near the stern, came up with this rig. A thin bendable piece of scrap wood.
                          Click image for larger version  Name:	I_IMG_9343.jpg Views:	0 Size:	52.4 KB ID:	188833
                          Continued the cut from the main cut to the line.
                          Click image for larger version  Name:	J_IMG_9341.jpg Views:	0 Size:	54.8 KB ID:	188832
                          Click image for larger version  Name:	K_IMG_9342.jpg Views:	0 Size:	56.4 KB ID:	188834
                            • 14006
                            #73
                            Excellent job, Ken. Here's a scribing-sawing tool I made for a similar task:
                            • Ken_NJ
                              • Sep 2014
                              • 1006
                              #74
                              I do have the tools I used on the Marlin, you remember that. I used a pointed hard tipped tool on the Marlin. I'll keep that scribing-sawing tool in mind, looks interesting and useful. I did use the razorback saw for a quick cut to be shown later, the same one Mike used on his XXIII to make the deck cut.
                              • Ken_NJ
                                • Sep 2014
                                • 1006
                                #75
                                Bow radial cut
                                For the bow radial cut I heated a strip of acrylic with the heat gun and formed it around the hull. Then anchored it in position and cut the slot with the Exacto blade.
                                Aft radial cut
                                This was more simple, used a straight edge and juts made the cut.
