Project 665 Whiskey long bin 1/50
    Greetings! The current state of streamlining the stern. Backing everything up with filler was necessary as there occuredsevereal perforations as espected. Will apply primer or flat black to check symmetry, not finished yet.
ID:	193550 Click image for larger version
ID:	193553 Click image for larger version
ID:	193552 Click image for larger version
    And the drill bits:
    Hi, available on Amazon:
    https://www.amazon.de/Proxxon-Universalhalter-UHZ-Zwinge-28610/dp/B0017NOVR2/ref=asc_df_B0017NOVR2?mcid=44e445f5ad8d3d2d96dade5 d4b9ee8e3&th=1&psc=1&tag=googshopde-21&linkCode=df0&hvadid=697080321013&hvpos=&hvnetw = g&hvrand=6208550217909786270&hvpone=&hvptwo=&hvq mt =&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9042931&h vt argid=pla-423451921377&psc=1&hvocijid=6208550217909786270-B0017NOVR2-&hvexpln=0
    The desk clamp is removable.
    After checking with my reference pictures, i extended the floodholes under the sail. Some minor work done. An old propeller stuck onto the rotary tool effectively blows away all the dust during the milling so one can see the drawing.
    Click image for larger version Name:	20260120_223556_copy_2040x1148.jpg Views:	0 Size:	62.6 KB ID:	193224 Click image for larger version Name:	20260120_220931_copy_2040x1148.jpg Views:	0 Size:	51.6 KB ID:	193225 Click image for larger version Name:	20260120_211303_copy_2040x1148.jpg Views:	0 Size:	52.3 KB ID:	193223
    Next will be finishing the torpedo shutters.
    Where could I get the rotary tool bit and such a mounting for the drill to make my own flood holes please?
    Another view down the stern, right side only with angled edge yet. Still way to wide. Best guess i put in filler from the inside so i might remove more "meat"!Click image for larger version  Name:	20260125_214955_copy_1148x2040.jpg Views:	0 Size:	56.8 KB ID:	193318 Click image for larger version  Name:	20260125_215026_copy_1148x2040.jpg Views:	0 Size:	48.7 KB ID:	193319 Click image for larger version  Name:	20260125_215019_copy_1148x2040.jpg Views:	0 Size:	45.7 KB ID:	193320
    Now my model, started with trimming the edge:
ID:	193315 Click image for larger version
ID:	193314 Click image for larger version
ID:	193313 Click image for larger version
    Very quiet here...
    I made a custom grinding drum for fine tuning of my hand-ground tubedoor channels to achieve a perfect semilunar groove. Worked well, applied a thin coat of nitrofiller afterwards to cover the tool marks (no picture).
    Click image for larger version  Name:	20260125_082429_copy_2040x1148.jpg Views:	0 Size:	52.2 KB ID:	193311 Click image for larger version  Name:	20260125_111425_copy_2040x1148.jpg Views:	0 Size:	51.7 KB ID:	193310
    The stern end of the model is sadly far off the original and i am trying putting it to shape without carving holes into the sides that will need backing up laminating from the inside. Not yet sure about this.
    Problem: the stern is way to fat just in front of the rudder and the kit seem to simply beeing cut out. No streamlining, cross-section is wrong. Knife-stern turned to axe-blade. Stupid stupid stupid...
    Am sure i will not be able to turning this into scale shape without tebuilding this entirely since here, the wall thickness is only "normal", compared to 5mm midships. Not much tolerance to remove material. So i step by step am trying at the moment to grind in a credible taper, the rest will be coveted by the massive rudder itself...hopefully...
    So this is what a whiskey looks like in general, though the 665 had a Foxtrot-layout with shrouded props and no stern tubes:
    Click image for larger version  Name:	projekt-613-S359-stern.jpg Views:	0 Size:	59.1 KB ID:	193309
    ...and the model's stern for comparision( elder picture)
    Any tipp how to implement SHARP pictures? I am taking 12 to 50M photos jpeg, resizing them with a picture resizer app to site specs and they are still brilliant on my phone, yet in here all the details get lost...
    Some more pictures:
    Click image for larger version  Name:	20260124_002041_copy_2040x1148.jpg Views:	0 Size:	58.6 KB ID:	193300 Click image for larger version  Name:	20260124_001848_copy_1148x2040.jpg Views:	0 Size:	56.2 KB ID:	193301 Click image for larger version  Name:	20260124_001230_copy_2040x1148.jpg Views:	0 Size:	53.5 KB ID:	193303
    Putting things back together to check the overall look
ID:	193292 Click image for larger version
ID:	193293 Click image for larger version
ID:	193294 Click image for larger version
    The tubedoors and some groups of the floodholes below the fwd sail were filled up again. The channels were that made by grinding in an initial groove with the machine and than using the template and a grinding drum by hand. Slight corrections are necessary, yet i think it looks about right now.
    Click image for larger version  Name:	20260123_232230_copy_1148x2040.jpg Views:	0 Size:	50.4 KB ID:	193290 Click image for larger version  Name:	20260124_000559_copy_1148x2040.jpg Views:	0 Size:	52.5 KB ID:	193288 Click image for larger version  Name:	20260124_000742_copy_1148x2040.jpg Views:	0 Size:	50.2 KB ID:	193289
    Started on the shutter doors. The front part was easy. Made a template for the rear section and found my original error: the depht of the tube muzzles as made with the kit are already too deep plus they're entirely wrong shaped.I should have filled them flush and made them all new from the start. Will remove the brown nitro-filler, make a rounded stencil from a piece of pipe with appropriate diameter and push it into fresh filler applied to the recess to produce the channel. Otherwise, it's filling all up again and grinding in a new channel...
    Click image for larger version  Name:	20260121_180148_copy_2040x1148.jpg Views:	0 Size:	49.1 KB ID:	193236 Click image for larger version  Name:	20260121_212222_copy_1148x2040.jpg Views:	0 Size:	41.6 KB ID:	193237 Click image for larger version  Name:	20260121_212216_copy_1148x2040.jpg Views:	0 Size:	46.8 KB ID:	193234 Click image for larger version  Name:	20260121_213450_copy_2040x1148.jpg Views:	0 Size:	46.2 KB ID:	193235
    To the stern:
ID:	193219 Click image for larger version
    An overview:
ID:	193215 Click image for larger version
ID:	193216 Click image for larger version
