3D printed 1/48 Thresher
    Thank you sir. Just 5 more parts to print...
    Excellent work, sir. This will be a stunner!
    Two 'rr's'.
    The forward hatch detail was just a little to prominent for my taste so I made a slight change.
    Before...
    Click image for larger version  Name:	20210807_142054.jpg Views:	0 Size:	47.5 KB ID:	152400
    After...
    Click image for larger version  Name:	20210813_195912.jpg Views:	0 Size:	44.1 KB ID:	152401
    It's not quite as pronounced now. I will do the same for the aft hatch after the part is printed. I am really liking how this particular boat is turning out.
    Actually, a couple of the extra hatches that David Ruiz made for his Type IX build I am working on will fit perfectly on this sub. I should be able to come close to following David Merimans fine example of this on his Threshers. I still have to make the hatch cover plate but that will be easy.
    I wish I could make it but I can't swing the time away for it and SubFest too. Bummed.
    Nuts. See you in Georgia then...
    Excellent! Thanks again.
    Anytime. You going to Groton?
    Hey David, can you tell me a little more about this hatch detail?
    OK. Then it could have been. I tried to find the date it was first published but showed it was much later.
    I believe it was republished in 1981 and after 2000.
    The first three sections of the hull are printed. The detail of the files is exceptional to say the least and the parts fit together very well. I have spent only a minimal amount of energy sanding them to the point that one good coat of high fill primer (Finish 1) will be all that is needed before paint. I am going to make brass catches to slide lock the upper hull to the lower hull to help lock the two together through the center. The ABS+ is some good stuff and the Ender 5+ is printing great. The way the parts are designed there is minimal if any need for support structures. I hate wasting filament on supports. I also downloaded and printed a 5-blade propellor (3-1/2") as I decided that is what I am going with. It may not be exactly true to the original prop but I really don't care. It will work. After I hit it with the primer it will make it very strong.
    Click image for larger version  Name:	20210807_142054.jpg Views:	0 Size:	47.5 KB ID:	152135
    Click image for larger version  Name:	20210807_143715.jpg Views:	0 Size:	44.3 KB ID:	152136
    Click image for larger version  Name:	20210807_143725.jpg Views:	0 Size:	39.9 KB ID:	152137
    Originally posted by Das Boot
    Polmar’s book was first published in 1964.
    It was over 40 years ago so it would have been copyrighted before 1981. More than likely it was "The Thresher Disaster: The Most Tragic Dive in Submarine History" by John Bentley published in 1975.
    Money says I checked out the same book. “The Death of the Thresher” by Norman Polmar.
