Though I still prefer ABS for my "working" components, I do use PLA for jigs, tools and Casting plugs.
I made up this "nozzle alignment" jig for PROTEUS.
Keep the Parallelism true among themselves and the center axis of PROTEUS.
For security reasons, you can see the armed minions keeping a close watch, after all we fear "the other side" will sabotage the boat even before it's future tragedy.
The round one near the propel tank I call "HWMNBN".
I did reprint, rebuild, the motor mounts. I did it this time in black so I won't have to paint them. They are designed to allow easy removal of the home-brewed brushless motor jet drive units for maintenance, repair or replacement.
Here I am test fitting the installation. Again, the PROPULSION units will be removable, even after the upper hull half is glassed in. "Robust design, easy access for maintenance.", is my motto!
Now that most issues have been resolved, the build process should accelerate. (Famous last words)
Something I want to share regarding the printing..........
I ended up purchasing a 2nd nozzle for the printer. One is strictly for ABS, and one for the PLA.
This way I don't have to clean them when I swap filament as the Monoprice VOXEL (a re-branded FLASHFORGE ADVENTURER 3). They're real easy to change, and they're only $23 ea. I unknowingly destroyed my first nozzle by cleaning it too harshly.
I did notice the increased bed heat degrades the Build-Tak used on the build plate!
100°c for ABS vs 50°c for PLA. I don't need to tell you for ABS that's the boiling point of water at sea level!
I do replace them more often, the crack and bubble lasting about 20 prints.
That bubble formed on a 2nd print and I couldn't calibrate the nozzle after switching to PLA for the Jig print.
Here is the bed after BOTH PLA jig prints. Not even a shadow from the two!
Again, I'm not saying WHICH material is better, that's up to you. I will always say it depends upon the (1) application and (2) personal preference.
This is just information to be aware.
FWIW, the next printer I look for will probable be the one most recommended for ABS printing.
Save this for PLA projects.
