    Will you be printing the ballast tank vent mechanism?
  • DrSchmidt
    On with the forward ballast tank...printed some big structural parts and placed them. Then the primer.
    Then the base coat and as the ballast tank is constantly exposed to sea water, one can weather quite a bit ( still I don't overdo it to keep the technical stuff visible)...
    Then the forward compresser air tanks....
    And the torpedo tubes ...
    And eveyrthing with the starboard half of the hull....
    Sheesh! Compared to the rest of what you have done it doesn't look too difficult at all.
  • DrSchmidt
    The bow section is more complex than I thought initially....ballast tank flor, diagonal stringers, ballast tank roof. That will be quite some work till all that ins in place.
  • DrSchmidt
    Thanks...and the prints look good to ;-)
    Made a fitting test and this seems to work out quite splendidly.
  • GwenB
    Very nice 3D modeling work there Dr.
  • DrSchmidt
    Now that the pressure hull and the openings in the fuselage approaching the finishing line, one can think about what else to display. For the bow I'm thinking about the space between the pressure hull and the muzzle doors. For the XXIII that'd be the forward ballast cell with the both torpedo tubes and the forward pressure bottles. The oil bunker below won't be displayed, and I think I'll keep the muzzle doors and the respective cowl panels closed, too. That's what I got so far in the new year...
  • DrSchmidt
    Thanks folks, and a happy new year!
    Cheers Andreas
    I am getting tired of saying ooooh and aaaahs, I would stare at this model for hours if it was in front of me. It is that good!
  • goshawk823
    Andreas,
    In its full glory! Beautiful! "Happy New Year"
    "Firemen can stand the heat."
    Andreas - That’s fantastic!
  • DrSchmidt
    Would be nice if you add some crew members.
    I have some…
    Last one for this year....
    Andreas,
  • DrSchmidt
  • DrSchmidt
    Had the patience and guts to start making the cut out on the starbord half of the hull. First taking precise measurements, then starting way smaller, and then opening the cuts to the final dimensions. Slow and messy, but one ends up with the right look....
