Next mold dilema.
I am going to have to pass off the Yankee II to Dave. Just don't have the time anymore for all the builds. Only molds I have time for is the 1/72 Charlie II and the 1/72 688. The 688 is the fist to be molded next week. -
Would rather die of lead poisoning then scribe. Go ahead make my day.1 PhotoLeave a comment:
Finally stupid Yankee missile hatches done. If I do one more boomer I will put a 357 Magnum to my head for a self made lobotomy.1 PhotoLeave a comment:
DavidLeave a comment:
Dave you get box with Foxtrot stuff in it? I should know better then to make boomers. Missiles doors are a pain. I will stick with SSGN's. Charlie II hull is almost all shaped. It is only 6" shorter then the Yankee.Leave a comment:
Started the scribe work on the Yankee. The surface coat of the epoxy and fiberglass powder is so hard I can barely scribe it with my scribe/jewelers file. Hopefully will have the Yankee hull scribe work done this week.1 PhotoLeave a comment:
Almost done with Yankee sail. Camera just doesn't pick up all the detail I have in sail.3 PhotosLeave a comment:
Here is what I have so far on the sail. Using PE parts that I had on hand. Went with the double row of vents instead of the 4 rows of vents. I thought it looked better.2 PhotosLeave a comment:
Found the perfect fit. Using a couple PE parts from a 1/144 Romeo kit. I am talking almost perfect.Leave a comment:
