On the ways: USS KRAKEN SS-370
  • SSBN659
    • 406
    I wasn't, I've just been interested in subs for a very long time and my name is "Will" Rogers. I'll be watching your build and enjoying it.
    SSBN659
    "Will" Rogers
    • QuarterMaster
      • Sep 2015
      • 1198
      SSBN659
      "Will" Rogers
      Well you got me! lol
      v/r "Sub" Ed
      • roedj
        • Sep 2008
        • 563
        HeWhoCannotBeShamed,,
        There comes a time in everyone's life when we must admit all(OK, some) of our faults.
        One of mine - when it comes to model building - is that I have absolutely NO skill at filing out limber holes. None I tell you - absolutely none. My attempts come out as trapezoids, at best, but mostly look like Rorschach test ink blots. I've tried all kinds of files; used many different tricks to outline the holes - all to no avail. I'm always on the lookout for yet another brilliant idea to lift my modelling skills. To that end I'm asking - what are you doing in this photo?
        Thanks ever so much.
        Commander Curious
          • 12287
          Commander Curious
          In almost all forms of fabrication, be it earth-moving (site survey); sheet-metal work (blue dye and scratch-awl); machining (plan reading and tool set-up); or sculpting (model analysis and lofting) there is the first step: lay-out. Or, if you will, mark-off, or lofting. The process of identifying the shape of the thing to be added to or subtracted from. Measurement plotted between established datum points, lines or planes. Sometimes the job requires creation of an intermediate model, a 'mock-up' (stiff paper, cardboard, clay, etc.), to understand the eventual fabrication process and materials selection -- the mock-up built from an easier/cheaper/quicker medium.
          Creation and use of stencils and templates is a must if the shape of the item you wish to create is to be accurate of form.
          (they don't teach this stuff in school anymore, do they? Just CAD and how to press the 'enter' key).
          So, here are various forms of lay-out and mock-up work:
            • 12287
              • 12287
                • 12287
                limber and flood-hole punching is no different. What you see there, scribed onto the surface of the model are the artifacts of a proper lay-out job; the identification of the vertical and horizontal demarcation lines that define the size and shape of the holes to be punched out. Just stay within the lines, and you're good.
                • Davidh
                  • Nov 2010
                  • 719
                  Seriously,
                  Someone needs to collect all this stuff and put it in a book. ( I don't have the time) I would buy it though! I get many inquiries from newbies, I just send them here and mention something about a one stop shop.
                  David H
                    • Oct 2017
                    • 719
                    Yes. His majesty shall call it "tales from the crypt" :-)))))
                    For HHSNBN will be dug out in a few millenias with his workshop as an example of the 21st century "homo modelensis"
                    Sorry couldnt resist
                    Jörg (continuing his bloody business right away)
                      • 12287
                      Originally posted by Davidh
                      Seriously,
                      David H
                      As you point out, this is the place. And, may I add: THIS FORUM IS THE BOOK!
                      If all you want is smiley-faced fluff, and empty platitudes the other forums are for you. However, if you want the straight dope on the subject of model submarining, from those in the know, this is the place.
                        • Oct 2017
                        • 719
                        Still would be a shame should your knowledge and experience get lost. Forum shutdown, server fails etc.. and its gone.i agree writing it down in a book to preserve it would be a great thing
                          • 12287
                          I've written countless articles for the magazines and contributed to several hard-back books. And you don't even know about it. Now you realize how worthless those means of knowledge transmittal are in todays world of Internet and robot made stuff.
                          You artfully dodge around the issue: How can you carry on when guys like me die. Then what? Does all that talent fade from existence as a brain decomposes inside a dark box buried in the ground; will that knowledge be lost to the world?
                          Take what comfort you can from this: The knowledge and experience we 'experts' have will not be lost if guys like you pick up the torch and continue the race. I learned from my betters, as you are learning now from me and my peers (few that there are).
                          Always be the student! As am I.
                          And when your time is up -- before you become a drooling idiot strapped to the bed and outfitted with a diaper and/or assume room-temperature -- make every effort to pass on as much knowledge as you can. It's your duty. And your only chance to secure for yourself a little slice of immortality.
                          Leave things a bit better than you found them. You do that, and your last thoughts will likely be good ones as the torch slips from your grasp into another set of hands.
                          Learn. And pass it on.
                          Back to work!
