Scratch build Soviet Project 661 Anchar "Papa" Class SSGN K-222 1/120 Scale.
    • Oct 2017
    • 715
    That would be just another candidate... great choice
      • 3545
      Project 658?
        • Oct 2017
        • 715
        I dont want to spoil this...davids turn
          • Oct 2017
          • 715
          @David : just got an announcement of my local post service papa arriving tomorrow i.e. today. YES!
          • Davidh
            • Nov 2010
            • 719
            Excellent!
            • Davidh
              • Nov 2010
              • 719
              Next hint.
              Putin stayed for the night.
              • Davidh
                • Nov 2010
                • 719
                “In April 2000, Acting President Putin stayed on board overnight at a depth of 50 meters, observing fleet exercises and participating in Russian submariner custom of drinking seawater. “. Well I guess that’s one way of dealing with leaks....
                  • Oct 2017
                  • 715
                  Sure sure .there are leaks, for its an old one
                  • Davidh
                    • Nov 2010
                    • 719
                    Hello all,
                    Here are are some pics showing the internal layout of Papa. I have left the outer cylinder off for clarity. The dive model is one unit without internal partitions. The Ballast tank is immediately in front of the
                    ballast tank pump which is on the front outer wall of the forward end cap. Forward of all of this is a 12 v SLA battery. Then lots of buoyancy foam. Immediately behind the front servo just behind the forward end cap is the break that allows me to pull the front off from the back. You can see a break in the tray where this occurs. I have also designed the electrical set up so that it 'auto connects.' (5 brass pins) I slide in either end and the plugs mate as you push the unit to close. I only have to tighten four nuts and attach the nitro line coming out of the forward ballast tank pinch to the ballast tank in front of it.
Name:	IMG_0467 (Large).JPG
Name:	IMG_0470 (Large).JPG
Name:	IMG_0468 (Large).JPG
Name:	IMG_0469 (Large).JPG
