USS SHARK SSN-591: Refit Log 2016-09-22
  • QuarterMaster
    • Sep 2015
    • 1198
    Lessons learned from the 2016 Groton Fun Run.
    1-After accounting for the mass of the additional 12V 7.5Ah SLA, and it's addition of CSF, I discover I was actually quite close to the original foam requirement. and I had left too much out.
    2-2.4 GHZ worked GREAT.
    3-WAAAY overpowered as evidenced by the sheared dogbone, as well as it becoming overpowered beyond "3" clicks on the TX throttle stick.
    So,
    A-Minor addition of CSF.
    B-Program the ESC for EXTREMELY soft start (Acceleration Level 1) to minimize impact on the drive train.
    C- Two inline 3:1 Gear reduction units, 9:1 reduction from Motor to Screw.
    Sea trials this Sunday
    Anyone recognize the 2nd gear reduction?? My SRP in action!
    First Gear Reduction unit on aft Bulkhead:
Name:	1st GR Unit.jpg
    2nd Gear Reduction unit on shaft support bulkhead. Click image for larger version
Name:	2nd GR Unit.jpg
    v/r "Sub" Ed
    • 12286
    A couple of old friends on display there, Ed.
    • QuarterMaster
      • Sep 2015
      • 1198
      YES, yes you do Master Jedi! _/|\_
      v/r "Sub" Ed
