Dumas retrofit
  • Steepturn
    • Aug 2015
    • 6
    Dumas retrofit
    I have a fully built Akula by Dumas with the watertight compartment that came with the kit Unfortunately no matter what I do it is not water tight my question is will a 2 inch EasyWTC fit this model I believe the internal width is slightly over 2 inches any advice would be appreciated Mark
    Hello, I had the same problem with a Subtek Albacore. I replaced all the original stuff with a 3" Subdriver. That was the smartest move I ever made. How much room do you have available, length and width? Post a picture if you can.
    • Steepturn
      • Aug 2015
      • 6
      I have three inches but David Merriman says a standard 2.5 will do the trick
        • 2848
        No comment! :-)
          I'm not sure that I'd be bragging about three inches even if I actually believed that 2.5 inches was standard......... just say'n.
            • 2848
            My sentiments exactly. Wasn't 2.5 the Pakistani Standard?
              Extra Whopper with pickle.
                • 12287
                I just finished converting one of these awful Dumas kits. Took it from a pile of screaming **** to a well running, statically diving, reliable, fast, highly maneuverable submarine. A standard 2.5" SD did the trick. I'll get some pictures of that work later.
                • Steepturn
                  • Aug 2015
                  • 6
                  Look forward to see those pictures. M
